replace text with regex
tva
Forum|alt.badge.img+12
I would like to change my string (which represents a uuid without dashes) to a uuid with dashes (8-4-4-4-12)
But I don't succeed. I know the regex to find the correct groups and a regex to replace with the dashes (found those in some forum for javascripters)
But if I use a string replacer and this regex to match my text : (\\w{8})(\\w{4})(\\w{4})(\\w{4})(\\w{12})
and this regex to replace my text: \\$1-\\$2-\\$3-\\$4-\\$5
My string isn't replaced but it gets my replacement string
ex:
00000000000000000000000004040154 -> \\$1-\\$2-\\$3-\\$4-\\$5 instead of 00000000-0000-0000-0000-000004040154
And I don't find any other solutions via some other transformer
What should I do?
Thx
Best answer by ebygomm
If you wanted to use the string replacer, replacement text set as \\1-\\2-\\3-\\4-\\5  should also work
Forum|alt.badge.img+39
  • June 4, 2015
You could use an attribute splitter with format string set as 8s4s4s4s12s
Then a list concatenator with - as a seperator character
tva
  • June 4, 2015
Why did I make it so hard when it could be this simple :)
Thx for the quick reply
  • June 4, 2015
tva
  • June 4, 2015
This one is even easier and made me think that I should look better at the help notes...
Flagged this one as best as it's better for me in my flow :)
gio
Forum|alt.badge.img+15
  • June 4, 2015
You should always be aware of different flavours of regulasr expressions. What you did was correct, the syntax was not the one the engine uses when using StringReplacer transformer.
FME does some nice flavour mixing on itself btw...
