replace string with tab dont work/ or how to?
  • Feb 7, 2020 7:36 PM UTC
  • 149 views
ronnie.utter
Forum|alt.badge.img+11
I have text input that are comma seperated like this:
1000,6617598.796,1468321.754,128.660,62
And my desired output should be tab seperated but I dont succed doing that with StringConcatenator.
It should be pretty easy =)
I am attaching a zip with 3 files
1. "Text_in" ( Input file)
2. "Text_out" ( FME generated output file)
3. Correct desired output "correct_output."
4. A FME template with the input file with some annotations.
@ronnieutter Try using StringReplacer and for the Replacement Text use the Text Editor to select the Tab character
ronnie.utter
  • Feb 7, 2020 8:23 PM UTC
thank you @markatsafe. Of course this is the solution =) Have a great day
