replace string in SQL transformer with another string
  • July 5, 2018
  • 5 replies
  • 65 views
fbastian73
Forum|alt.badge.img+12
I want be able to replace part of a generic table name with the current table name in the SQL statement within the sql transformer.
for example <LAST_YR_RIN_SCHEMA> with R_2017_01_01
is this something that can be done in the workbench?
i was told to use a private parameter but that wouldnt work and also to use a creator followed by attribute_creator followed by the sql_executor which is also not good as i only want to replace part of the table name not the entire name as shown in screen shot above.
thanks for your suggestions.
  • July 6, 2018
Hi @fbastian73, if you create an attribute that stores the entire SQL statement containing the placeholder '<LAST_YR_RIN_SCHEMA>', you can replace it with the StringReplacer and then set the attribute to the SQL Statement parameter in a SQLExecutor. This screenshot illustrates my intention.
Alternatively, you can also execute the @ReplaceString function in the SQLExecutor instead of using the StringReplacer, like this:
  • July 6, 2018
Where is your screenshot?
fbastian73
  • July 8, 2018
hi @takashi
sorry, i was sure the screenshot had attached. Here it is again.
I will try your suggestion and see how i go.
As you can see, i want to replace only part of the table name not the entire name.
thanks for your help.
  • July 9, 2018
hi @takashi
Thanks for posting the screenshot. I think that the method I suggested should also work even if the placeholder is only a part of the entire table name. If a single SQL statement contains two different placeholders, you can just use two StringReplacers in series.
fbastian73
  • July 9, 2018
hi @takashi,
it has worked for me with the first method you mentioned.
thanks again.
