Replace null values in JSONTemplater
  • Jul 20, 2020 3:19 PM UTC
  • 74 views
I currently have a template like this:-
    "pd_id" : fme:get-attribute("pd_id"),
    "name":fme:get-attribute("district_name"),
    "code" :fme:get-attribute("district_code")
Is it possible to add a rule that says: IF district_name is null then name = fme:get-attribute("pd_id")
  • Jul 20, 2020 3:36 PM UTC
Hi @davebarter, I think it would be easier to change the value of district_name to the value of pd_id if it was null, using an AttributeManager with Conditioinal Value setting before the JSONTemplater.
