Repair Invalid Polygon Geometry Type
  • October 14, 2021
  • 458 views
chris_acc
Forum|alt.badge.img+5
Repair Invalid Polygon Geometry TypeHello,
I wish to generate a count of points within Polygons [PointOnAreaOverlayer] but I am unable to generate a count for some polygons because of fme_rejection_code: INVALID_POLYGON_GEOMETRY_TYPE
These Polygons are either Self Intersecting or Multi Polygons. I believe I need to resolve this before I can start counting points inside but Aggregator and Geometry Validator do not seem to fix the issue.
Thanks.
Best answer by ebygomm
chris_acc wrote:
The problem with setting Aggregate Handling to Deaggregate is that it then produces too many polygons and I don't know how to merge them back again to the same input amount.
I added another Aggregator after PointOnAreaOverlayer which has helped a little but still a few too many.
There will be some polygons that have 0 Overlaps but I need to include them also.
You should be able to aggregate back after the point on area overlayer, it looks like you can group by the original OBJECTID and select _overlaps under Attributes to Sum
Forum|alt.badge.img+35
  • October 14, 2021
The PointOnAreaOverlayer does not accept aggregate polygons, you will need to deaggregate them - this can be done within the transformer by setting Aggregate Handling to Deaggregate. You will then need to combine totals from each part of the aggregated polygon to get a total
chris_acc
  • October 15, 2021
  • October 15, 2021
chris_acc
  • October 15, 2021
Thanks!
I think the main issue with the Aggregator following on from PointOnAreaOverlayer was that I had selected all of the fields to 'group by' instead of just selecting OBJECTID.
