Renaming a file turns it into a folder
  • Jan 25, 2021 5:14 PM UTC
  • 10 replies
  • 163 views
joe.fme
Hello all,
I've got a spreadsheet with filenames, and have been asked to rename the files in a folder/subfolders - with the filenames in the spreadsheet.
After joining them, which works fine, I then put it through an Attribute Manager to have the attached image as an output destination (Folders and a Document at the end).
I was wondering if anyone could shed any light on why the output files, from the FileCopy writer (both Copy and Move mode) come out as folders, and not the PDF files as they went in?
Best answer by alexlynch3450
Hi Alex, I had the file extension as part of the filename attribute, so it comes out as "file.pdf" but is seen as a folder. As for the fanout, that's not enabled, no. Would they be the way to go?
this would be an example of how you would copy file from local drive to an external device and rename it.
alexlynch3450
Forum|alt.badge.img+16
Did you add the file extension after?
Are you using the 'fan out' parameter?
joe.fme
  • Jan 25, 2021 9:08 PM UTC
alexlynch3450
do you use "filecopy_source_dataset", "filecopy_dest_dataset", and "filecopy_dest_ filename" attributes when writing?
joe.fme
  • Jan 26, 2021 8:58 AM UTC
Morning,
That I do - they are as follows. Mind the lame attempt at censorship, it's just due to my job.
filecopy_source_dataset = Path_Filename
filecopy_dest_dataset = Output
filecopy_dest_filename = Renamed
Thank you for your help. Ive managed to tweak it whereby it creates the folders I need, but it doesn't put the files into it, with the errors as follows -
2021-01-26 08:48:43| 13.3| 0.0|WARN |File Copy Writer: Ignoring the destination filename '50079212042 Site MPP.pdf' because the source dataset '20190226134825_124852.pdf' was not a file. Destination file names are only used when the source dataset is a file
2021-01-26 08:48:43| 13.3| 0.0|WARN |File Copy Writer: Feature contains an invalid source dataset '20190226134825_124852.pdf'. No file operations will be performed for this feature
alexlynch3450
so you rename the attribute 'Path_Filename' to filecopy_source_dataset?
also, is the fullllllllll filepath used for filecopy_source_dataset--drive/server and all?
alexlynch3450
  • Jan 26, 2021 12:43 PM UTC
joe.fme
  • Jan 26, 2021 3:52 PM UTC
Hi Alex,
Cheers for that! I got it working in the end for the most part - however there are still a few that show up as folders with PDF at the end. Any idea what might cause this?
joe.fme
  • Jan 26, 2021 4:01 PM UTC
Edit - Just realised as some have different folder structures, I'm now using the FilenamePartExtractor to move these to the output folder
You're still a star for getting me on the right track :)
alexlynch3450
I assume this is FME Desktop?
Test by changing "Copy Subfolders:" to 'No' and "error on Non-Existent Source:" & "error on Invalid Destination" to 'Yes'.
In addition, check your log file...I get you're trying to conceal sensitive information, but this would be so much easier if I could see what you're seeing. No Biggie tho
joe.fme
  • Jan 26, 2021 4:24 PM UTC
Yeah it's a bit of a pain. Needless to say though, I got there in the end - once I could put the attribute manager there and say "if the subdirectory contains this, then put that folder first, then the subfolder and the file"
Instead it was originally saying to "put the folder, then the other folder - as the PDF"
Paid off :)
