Rename file extension using SystemCaller not working
  • Jun 26, 2019 2:39 PM UTC
  • 152 views
I'm trying to rename .wld files to .jpw after an image has been processed but the following dos command is not working. Any idea?
oscard
Forum|alt.badge.img+23
  • Jun 26, 2019 2:45 PM UTC
Have you tried ren "$(output_folder)" *.wld *.jgw?
Also, check if the command works all right outside FME.
Forum|alt.badge.img+63
There should be a \ between the last part of the output folder and the *.wld, so this should work:
ren $(output_folder)\*.wld *.jgw
Also, if there's spaces in the pathname, you might need to wrap that parameter and the \*.wld in " marks
erik_jan
Forum|alt.badge.img+26
  • Jun 26, 2019 2:46 PM UTC
Looks like there is a space between the output folder and the file name. That should be one continuous path without spaces. If the path contains spaces, use quotes as mentioned by @oscard
 ren "$(output_folder)\*.wld" *.jgw
Fixed it with the above. You've all been helpful, thanks!
