Rename file extension after translation
  • April 24, 2018
  • 8 replies
  • 46 views
I have a Workspace that generates a .jpeg file with a named coordinate file. wld. Is there no way to generate the .jgw file or rename it to .jgw after translation?
erik_jan
Forum|alt.badge.img+26
  • April 24, 2018
Use the FeatureWriter transformer instead of the JPEG writer and follow the Summary port by a SystemCaller transformer to rename the file.
  • April 24, 2018
@erik_jan, helped me a lot. This is way. But the systemcaller don't work properly. I use this command: C:\\Users\\Usuario\\Desktop\\teste /ren *.wld *.jgw, but nothing happens.
erik_jan
  • April 24, 2018
Try this command line:
ren C:\\Users\\Usuario\\Desktop\\teste\\*.wld *.jgw
erik_jan
  • April 24, 2018
This is the help for the DOS RENAME command:
ren /?
Renames a file or files.RENAME [drive:][path]filename1 filename2.REN [drive:][path]filename1 filename2.Note that you cannot specify a new drive or path for your destination file.
  • April 25, 2018
If you need to rename a file using the SystemCaller, pass the whole thing below as the command line:
c:\windows\system32\cmd.exe /c "ren c:\temp\source_file.txt destination_file.txt"
You cannot use the "ren" command directly since it isn't an executable by itself, only a function defined inside the command line shell. This is not a limitation of FME, it's just how Windows is :-)
erik_jan
  • April 25, 2018
Thanks @david_r, I did not know that.
Or create a batch file with this command line and call the batch file. In that case you do not need to call the cmd.exe
  • April 25, 2018
Agree, that's also a good solution.
  • April 25, 2018
Thank you all, solved my problem.
