Remove Trailing Spaces
Hi there,
I want to remove all spaces after a string. Example:
TestString1[ ]TestString2[   ]
whereas only the empty spaces after TestString2 should be removed.
I have a solution for removing leading spaces with the StringReplacer which is ^[\s]* but I want to remove only the empty spaces at the end.
Many thanks and kind regards
Thomas
Best answer by jdh
Use an AttributeTrimmer with Trim Type Right and Trim Characters {space}
jdh
Forum|alt.badge.img+41
  • May 25, 2016
jdh
  • May 25, 2016
If you wanted to go the regex route it would be [\\s]*$
  • May 25, 2016
Many thanks @jdh The AttributeTrimmer works perfectly! I had forgotten how many wonderfuly transformers FME has on board :) And thank you also for the tip with the regex, have to learn this topic very soon :)
