Remove space and Space* from the name ensuring John Doe*/ John Doe * converts to John Doe. What transformer and parameters should be implemented
  • Apr 2, 2025 3:43 PM UTC
  • 76 views
aashnaparikh
Forum|alt.badge.img+3
Remove space and Space* from the name ensuring John Doe*/ John Doe * converts to John Doe.  What transformer and parameters should be implemented?
Tried to use the Attribute Trimmer but it only removes either of it.
dustin
Forum|alt.badge.img+36
  • Apr 2, 2025 4:05 PM UTC
If you use a StringReplacer with the Replace Regular Expression mode, you can use this in the Text To Replace parameter. Leave the Replacement Text parameter blank.
\s?\*
aashnaparikh
  • Apr 2, 2025 4:14 PM UTC
Thank you. It works
