Remove newline space
  • March 27, 2019
  • 6 replies
  • 1051 views
jugoslaviaa
Hi all,
In the attribute of my data, there is sometimes newlines and I want to trim them. I am using the AttributeTrimmer however it is not working.
The data looks like this:
{33}SCHOOL, BUS ONLY 8-10AM 12-4PM EXC SAT-SUN-HOL SEPT
THRU JUNE,
I want to trim it like this:
{33}SCHOOL, BUS ONLY 8-10AM 12-4PM EXC SAT-SUN-HOL SEPT THRU JUNE,
Is my setting not correct?
Best
  • March 27, 2019
You'll need to use the StringReplacer for this.
The AttributeTrimmer only checks the start and end of the attribute value, so the newline embedded somewhere in the middle won't be removed.
jugoslaviaa
  • March 27, 2019
What should be the text to replace? I tried \\n and it did not work out.
jugoslaviaa
  • March 27, 2019
Thank you! It worked with /v :)
  • March 27, 2019
Excellent. You can also simply open the Text Editor window and manually enter a newline on its own.
nmartin
Participant
  • Participant
  • June 18, 2020
So I didn't scroll down to this response and was tearing my hair out for 10 minutes trying /v \\r\\n \\n etc.
I eventually found https://knowledge.safe.com/questions/48695/how-to-split-a-delimited-string-with-a-carriage-re.html which is a related issue where the answers there were the same as you gave here.
Obvious only in hindsight, as I never would have expected I would need to go into the text editor than just use the text box provided in the StringReplacer
r_huesken
Forum|alt.badge.img+5
  • March 2, 2023
Just a tip for anybody who is trying to split a multiline text attribute using an AttributeSplitter:
  1. Use the text Editor to specify the newline: type <enter so your first line is empty, then close the text editor. So obvious one might overlook this option.
  2. Expose the list attribute list that is created after the AttributeSplitter image
