Remove fme attributes, to not be transposed using the attributeexploder
  • Jul 2, 2019 2:03 PM UTC
  • 191 views
jonasbengtsson
I'm trying to remove the hidden attributes fme_geometry and fme_type from the MSQQL_ADO reader before using the AttributeExploder, so that these attributes want be transposed, in order to speed up the process. If these attributes are exploded, I need a testfilter afterwards to remove these values. I've tried to expose the fme_gemetry and fme_type and then tried an AttributeRemover and BulkAttributeRemover to remove this values, without success. I was able to remove the default multi_* attributes with the BulkAttributeRemover, but not fme_attributes.
Is there anyway to remove fme_geometry or fme_type.
Thanks in advanced
/Jonas
Forum|alt.badge.img+54
  • Jul 2, 2019 2:16 PM UTC
Attributes that start with fme are 'protected' from the bulk attribute remover
Easiest way to remove the fme attributes is with a pythoncaller, see @david_r answer here
https://knowledge.safe.com/questions/48342/is-it-possible-to-remove-hidden-attributes-without.html
jonasbengtsson
Thank you @egomm. Knew it was possible but could find out how
