remove duplicates values from Excel
  • Jul 27, 2022 12:09 PM UTC
  • 132 views
mr_fme
Forum|alt.badge.img+9
I have one column in my excel file that show tha values like below:
VARIEDADE
ABB4, ABB2, ABB4, ABB5
ABB4
ABB2, ABB5
ABB2, ABB2
ABB4, ABB4, ABB4, ABB4
The two last lines have the same value separated by comma. I would like to simplify like below:
ABB2
ABB4
How Can I do this?
Thank´s
Best answer by dustin
I would break the values out into a list using AttributeSplitter, remove the duplicates via ListDuplicateRemover, then concatenate the unique values back into the original attribute using ListConcatenator.image
dustin
Forum|alt.badge.img+36
  • Jul 27, 2022 12:23 PM UTC
mr_fme
  • Jul 27, 2022 12:49 PM UTC
Thank´s very good!!
devbyisty
Participant
  • Participant
  • Apr 11, 2025 5:07 PM UTC
You can easily remove duplicate values from your comma-separated list using an online tool. In Excel, you can also use:
=TEXTJOIN(", ", TRUE, UNIQUE(TRIM(TEXTSPLIT(A1, ","))))
This formula splits the values, removes duplicates, and joins them back. Hope this helps!
