Remove duplicate entries
  • Apr 22, 2016 10:38 AM UTC
  • 99 views
Dear FME community,
I have a road network which has duplicate entries. The attributes differs just in one attribute ("bescheid_nr"), all other attributes are the same in the example. I want to keep only the feature with the highest number in the attribute "bescheid_nr" when all other values are the same. In the screenshot the feature 2 to 6 should be removed. They are not valid. Is there a way how I can filter them out so only the first entry in the screenshots gets preserved (all 5 have different geometries)?
Kind regards
Thomas
Forum|alt.badge.img+54
  • Apr 22, 2016 10:52 AM UTC
Take a look at the matcher
patrick_koning
Forum|alt.badge.img+7
Put them all in a listbuilder sort the list and then take the desired item from the list.
Be sure to keep the geometry if you wat to keep it in a different attribute so you can restore it after the listbuilder and sorter. In the list the geometry gets lost. but with a geometry extracter into an attribute and after that a geometryreplacer to restore the geometry it should work just fine.
  • Apr 22, 2016 12:28 PM UTC
Hello,
If your duplicates are only attribute based (no need to match the geometries), I'll do it this way.
  1. Sort your features based on bescheid_nr (Sorter)
  2. Filter out the duplicates based on grundbescheid_nr (DuplicateFilter)
  3. Keep the unique and merge back the duplicates based on grundbescheid_nr and bescheid_nr (FeatureMerger)
Regards,
Larry
