Remove duplicate entries
  • October 27, 2016
  • 96 views
Dear FME community,
I have a dataset which has for example the following two attributes:
- grundbescheid_nr
- bescheid_nr
If there are two identical rows with the same value in grundbescheid_nr (e.g. grundbescheid_nr= 183101), then only the entry with the higher number in bescheid_nr (in the example bescheid_nr = 186754) should be preserved. The entry marked with the blue background (bescheid_nr = 185582) and it's geometry should be deleted. The lower one(s) should therefore be eliminated.
I suppose I could do it with a ListBuilder somehow, but I'm not yet sure how to do it exactly. Is there an easy way to solve this?
Kind regards
Thomas
Best answer by david_r
You can use a Sorter and sort descending on bescheid_nr. Then use a DuplicateFilter (was called DuplicateRemover before FME 2016) on grundbescheid_nr and only take the unique record.
This works since the unique output port will always output the first unique value entering.
  • October 27, 2016
  • October 27, 2016
Wonderful, that works perfectly! Many thanks.
  • October 28, 2016
Hi @thomask, I also use the combination of Sorter and DuplicateFilter usually in a similar case, but it's not the only way. For example, the InlineQuerier with this SQL statement could also be effective. FYI.
select a.* from features as a
inner join (select grundbescheid_nr, max(bescheid_nr) as maxBescheidNr
    from features group by grundbescheid_nr) as b
on a.grundbescheid_nr = b.grundbescheid_nr and a.bescheid_nr = b.maxBescheidNr
  • October 28, 2016
Thank you very much @takashi! This look good, but I'm not so experienced in SQL. It's been a while since we had it in our lectures :-)
