Relate point to autocad_solid3d.
  • Aug 28, 2019 8:46 AM UTC
  • 5 replies
  • 87 views
nielsgerrits
Forum|alt.badge.img+67
I try to relate boreholes (points) to 3D Solids from Cad. (autocad_original_entity_type = autocad_solid3d)
FME does read the 3D Solids as surfaces. (fme_geometry = fme_aggregate / fme_type = fme_surface)
The way I found to do this is to convert the surfaces to polygons with a SurfaceFootprintReplacer, then use a SpatialRelator to define the relation.
But this takes a lot of time as I have quite a bit, quite big solids.
So I wonder: Am I doing this correctly? Does an alternative solution exist?
Thanks!
Best answer by itay
Hoi @nielsgerrits,
How about the 2DForcer?
jurgen
Forum|alt.badge.img+15
  • Aug 28, 2019 12:47 PM UTC
Hej Niels,
It's still not optimal (hope someone else finds a faster sollution) but replacing the SurfaceFootprintReplacer with a Hullreplacer (concave)() made it quite a bit faster for me (halved the runtime, with the same results).
Then again, it works for this geometry. I am not sure if the hullreplacer could cause problems for other shapes.
nielsgerrits
Hej Niels,
Hoi Jurgen, thanks for the suggestion. I did some testing with it but will keep the footprintreplacer for now. If this is how it works I'll just have to wait for the data being processed. :-) Just want to make sure I don't miss a better solution.
itay
Forum|alt.badge.img+19
  • Aug 28, 2019 2:09 PM UTC
Hoi @nielsgerrits,
nielsgerrits
Hoi @nielsgerrits,
Great idea @itay! Works like a charm. Processing time went from 48 to 2 seconds for the sample feature.
itay
  • Aug 29, 2019 9:16 AM UTC
Glad I could help.
