Regular Expression for Uppercase Only
  • October 24, 2019
  • 6 replies
  • 308 views
deanhowell
Forum|alt.badge.img+24
I am trying to set up a tester or string searcher transformer to test if the entire string is uppercase but can't get it to work.
THIS SHOULD PASS
but
This Should FAIL
Best answer by danullen
If it finds [a-z] it's a fail. As simple as that? :)
  • October 24, 2019
  • October 24, 2019
This setting could work as expected.
Forum|alt.badge.img+40
  • October 24, 2019
I'd be tempted to ignore regex and do the test like this, if it's a possibility you'll have apostrophes, hyphens or similar in your input
e.g. THIS SHOULDN'T FAIL
But this should work as well - only values without any lowercase letters pass
deanhowell
  • October 24, 2019
Thanks @danullen, that worked perfectly, keeping it simple :)
deanhowell
  • October 24, 2019
Thanks also @ebygomm, that is a much more elegant solution. I love that there are multiple ways to get the same solution.
deanhowell
  • October 24, 2019
Thanks @takashi, as always you are a terrific help. I am always impressed by the help provided by the members on this forum.
