Regex to extract string
  • August 16, 2023
  • 963 views
katt
Forum|alt.badge.img+12
When I am using a regex in a string searcher, the output is as expected. When I am using the same regex as @FindRegularExpression in the Attribute Manager, my script always fails. What do I need to modify in the Attribute Manager regex? Thanks21
dustin
Forum|alt.badge.img+31
  • August 16, 2023
@FindRegularExpression returns the index of the match. @SubstringRegularExpression will return the match itself, similar to the StringSearcher.
katt
  • August 16, 2023
@dustin​ I tried it previously as well but it didn't work either. Am I missing anything ?3
dustin
  • August 16, 2023
There are additional inputs needed for @SubstringRegularExpression. Try this:
@SubstringRegularExpression(@Value(path_windows),.*(?<=\\),0,0,0,caseSensitive=TRUE)
