Regex multiple character replace
  • April 4, 2017
  • 7 replies
  • 439 views
Can anyone advise me what regex is required (potentially within StringReplacer) to remove ALL characters in a string EXCEPT
lower case a to z,
upper case A to Z
number sign #
colon :
I want to smash/collapse the entire string together removing everything except occurrences of these 54
characters.
Thanks in advance,
Rob
Desktop (2015.1)
Best answer by gio
[^(a-zA-Z#:)]
Forum|alt.badge.img+7
Hi @rob14
I think this will help you. It will select everything except the things that should not be selected so you can replace it with ''
[^(a-z|A-Z|#)]
  • April 4, 2017
Hi @jeroenstiers,
Thanks very much, the syntax above nearly does everything (just need to leave the colon in place).
I tweaked your code, which appeared to leave the colon as well; however, I am not sure of this is the 'correct' use of regex [^(a-z|A-Z|#:)]
Should there be an additional vertical bar between the # and : (is the bar technically acting as a logical 'OR' or maybe an 'AND' as it is in fact a multiple negation?) to give me [^(a-z|A-Z|#|:)]
Thanks again,
Rob
gio
Forum|alt.badge.img+15
  • April 4, 2017
[^(a-zA-Z#:)]
gio
  • April 4, 2017
because else it would also not select a "|" if you use that.
Anything between square brackets is a character class. So adding a pipeline character is a character and not a pipeline.
In this case it is a negated character class.
and if you want to negate a "-" you would need to add a escaped one.
[^(a-zA-Z#:\\-)]
  • April 4, 2017
Hi @gio,
Thanks for the further explanation, regarding the loss of regex 'special character' super powers if included within the class brackets[]. Essentially meaning a 'special character' becomes a 'normal' search criteria (escape pending) (I guess the brackets are to special characters what Kryptonite is to Superman).
I have revised my StringReplacer to [^(a-zA-Z#:)] and all is well.
Thanks again,
Rob
  • April 5, 2017
[^(a-zA-Z#:)]
I think the regex excludes the round brackets ( ) too. Probably this regex would exactly match the requirement.
[^a-zA-Z#:]
[^(a-zA-Z#:)]
I had to answer in a hurry. Thanks for finding the mistake!
