Regex in StringSearcher
Hello,
I'm trying to find only the letter D on its own in a string such as the following: B,G,D,DM,TD,DM,TD,D. In this example, that would be 2 D's (the third D and the last D I've marked in red).
Unfortunately, all the regex expressions I've tried also gets the D within TD (e.g using D,|D$).
Thanks.
Tony
Best answer by takashi
Hi @aviveiro, the meta character '\b' that represents a word boundary (including space, start/end of a text, comma, period etc.) might help you. For example, this regex matches a single character 'D' sandwiched by word boundaries.
(?<=\b)D(?=\b)
  • March 15, 2020
(?<=\b)D(?=\b)
bwn
Forum|alt.badge.img+26
  • March 15, 2020
@aviveiro Don't forget that in the case of simple situations such as dealing with value delimited strings, there is also AttributeSplitter.
arnold_bijlsma
Forum|alt.badge.img+14
(?<=\b)D(?=\b)
@takashi: Excellent answer. I am still not fully familiar with the power of \b.
Just to note: In 'normal' RegEx you indeed need the lookahead and lookbehind assertions. But in the StringSearcher, you don't need them, as it will capture all instances, and \b by definition captures nothing, so you just use
\bD\b
and specify the first list in the Advanced section.
  • March 17, 2020
(?<=\b)D(?=\b)
@arnold_bijlsma, you are right. Lookbehind and lookahead are't essential here. Thanks for pointing it out.
gio
Forum|alt.badge.img+15
  • March 17, 2020
@takashi
@aviveiro
@arnold_bijlsma
word boundary \\b represents all non word characters so \\bD\\b matches the string, because it matches some part(s).
Following is not correct to say the least:
To capture an asertion you need to enclose it in braces: \\b(D)\\b
(of course there is a non-capturing version (?:) will cap but not report.
Contrary to popular believe \\b is an (zero length)assertion. So if you enclose it in braces, it will be grabbed. Same goes for begining, end.
A regexp result always shows the enire string if grepped. The All Matches List Name.
To get the indvidual captured D's you will need to enclose it in braces and use Subexpression Matches List Name.
Furthermore, there are not many flavors hat use lookbehind. Python's version does, which will please you guys i guess.
there is a site that shows all flavors and their reaches.
Lookbehind can be emulated by lookahead and some more regexp fiddling.
Of course it may have changed since last i read on it.
Read up on the matter: Jan Goyvaerts work is awesomely suited for that. (see RegeX Buddy. His document is there) But there are plenty good ones.
arnold_bijlsma
The key thing is that for the RegEx implementation in the StringSearcher you don't need the lookahead/-behind assertions nor any grouping brackets to capture both instances of the single letter D in the test string.
But you're right that other implementations outside FME could give a different output.
