Regex Different Result FME vs Online
  • Feb 21, 2023 12:04 PM UTC
  • 63 views
tiztrain
I am building a simple regex expression which extracts the letters of the alphabet including the letters with accents. What I am having trouble with is using FME's regex editor vs the online one and the conflicts.
The example below I have screenshots of regex101 online and FME regex editor and they both show different results for the expression:
[a-zA-Z\\sčćđšž]+
RegexExpressionsFMERegexExpressionsRegex101I need help understanding why is this and what to do to get around this issue?
Also, how do you apply regex flags?
Forum|alt.badge.img+54
  • Feb 21, 2023 12:53 PM UTC
Have you actually tried running the regex? I think this is an error in the regex editor only and running will give you the same result as you see in regex101
Looks like there's a small bug in the test string preview. When you try running the regex in FME, it should work as expected.
tiztrain
  • Feb 21, 2023 1:25 PM UTC
Using 2021.1 workbench so it has probably been fixed. Spent so much time trying to figure it out and this is all it is ha. Thanks guys
