Reduce Pdf size in batch
Trying to reduce multiple pdf size in one location. Tried PDF pro but had to pick location and click ok for every file (260 qty). Is there a way in FME that can batch reduce size for the pdf.
Thanks
Best answer by erik_jan
Sorry, but FME does not have a PDF Reader (yet).
But FME has a reader for "Directory and File Path".
This returns the file name and path.
Combined with the SystemCaller transformer, you might be able to call PDF pro using a command line and the file name from the reader.
That way looping through the files without manual interaction.
erik_jan
Forum|alt.badge.img+18
  • March 28, 2017
pratap
Forum|alt.badge.img+11
  • March 29, 2017
Size reduction in what sense, either by reduce the pages per file or page size or any other???
gio
Forum|alt.badge.img+15
  • March 29, 2017
no pdf writer???
I guess u mean no pdf reader.
If pdf pro has command line options, you could use a batch file to do it. (havn't find any on the net though)
erik_jan
  • March 29, 2017
gio wrote:
no pdf writer???
You are right. I meant no PDF Reader. Will edit my entry. Tnx.
mygis
Forum|alt.badge.img+14
  • April 3, 2017
Hi @majidachaoudhry,
It is perhaps off topic but we use CorelDraw at the office to reduce pdf size files in batch. Meaning that we can reduce those huge i.e: 12Mb files down to 500kb, depending on the requirements.
Just to sharing.
Cheers.
Lyes
