Reduce Pdf size in batch
  • March 28, 2017
  • 5 replies
  • 84 views
Trying to reduce multiple pdf size in one location. Tried PDF pro but had to pick location and click ok for every file (260 qty). Is there a way in FME that can batch reduce size for the pdf.
Thanks
Best answer by erik_jan
Sorry, but FME does not have a PDF Reader (yet).
But FME has a reader for "Directory and File Path".
This returns the file name and path.
Combined with the SystemCaller transformer, you might be able to call PDF pro using a command line and the file name from the reader.
That way looping through the files without manual interaction.
erik_jan
Forum|alt.badge.img+26
  • March 28, 2017
pratap
Forum|alt.badge.img+12
  • March 29, 2017
Size reduction in what sense, either by reduce the pages per file or page size or any other???
gio
Forum|alt.badge.img+15
  • March 29, 2017
no pdf writer???
I guess u mean no pdf reader.
If pdf pro has command line options, you could use a batch file to do it. (havn't find any on the net though)
erik_jan
  • March 29, 2017
no pdf writer???
You are right. I meant no PDF Reader. Will edit my entry. Tnx.
mygis
Forum|alt.badge.img+14
  • April 3, 2017
Hi @majidachaoudhry,
It is perhaps off topic but we use CorelDraw at the office to reduce pdf size files in batch. Meaning that we can reduce those huge i.e: 12Mb files down to 500kb, depending on the requirements.
Just to sharing.
Cheers.
Lyes
