Trying to reduce multiple pdf size in one location. Tried PDF pro but had to pick location and click ok for every file (260 qty). Is there a way in FME that can batch reduce size for the pdf.
Thanks
Thanks
Best answer by erik_jan
Sorry, but FME does not have a PDF Reader (yet).
But FME has a reader for "Directory and File Path".
This returns the file name and path.
Combined with the SystemCaller transformer, you might be able to call PDF pro using a command line and the file name from the reader.
That way looping through the files without manual interaction.
No account yet? Create an account
