Reading multiple geometry using sql executor
  • September 28, 2017
  • 13 replies
  • 93 views
f.kemminje
Forum|alt.badge.img+11
Can I read multiple geometry using sqlexecutor. In my case , i dont have two geometry in one table. i am extracting/constructing multiple (2) geometry from different tables and the sql gives resultset with two geometries in one row.
two geometry from sql resultset not from one table
and later i will deaggregate this and use these geometries for different purposes.
how can i achieve this using fme?
david_r
Which database are you using and how are the geometries stored?
One solution could be to cast both geometries to e.g. WKB and then use two separate GeometryReplacers to extract the geometries. Something like (pseudo-code):
select
  as_binary(t1.geom) as geom1,
  as_binary(t2.geom) as geom2
from
  mytable1 t1 join mytable2 t2 on t1.id=t2.id
Then expose "geom1" and "geom2" and send them to the GeometryReplacer as OGC Well-Known Binary.
f.kemminje
select
from
@david_r oracle sql says as_binary invalid identifier
as_binary
erik_jan
Forum|alt.badge.img+26
Why do you need to use the SQLExecutor transformer and not an Oracle Spatial reader or the FeatureReader.
In your case the SQLExecutor seems to complicate matters only.
david_r
For Oracle Spatial, use:
SDO_UTIL.TO_WKBGEOMETRY(geom)
Doc: https://docs.oracle.com/cd/B28359_01/appdev.111/b28400/sdo_util.htm#SPATL1250
For ArcSDE with an Oracle backend, use:
sde.st_asbinary(geom)
Doc: http://desktop.arcgis.com/en/arcmap/10.3/manage-data/using-sql-with-gdbs/st-asbinary.htm
david_r
It's pretty handy if you need to join several tables and haven't got the option of creating a view in the database.
david_r
as_binary
It's pseudo-code, you'll have to replace that with whatever your backend supports.
f.kemminje
i extractring the data by joining many tables. i use oracle spatial.
f.kemminje
@david_r
my database is oracle spatial
erik_jan
OK, I can see the point.
But in this example I would use two SQLCreators (not SQLExecutors), each with a query containing 1 geometry.
No need to de-aggregate afterwards.
f.kemminje
@david_r
Thank you David.
david_r
Not sure I follow. You mean doing the join in the workspace rather than in the database?
erik_jan
Yes, if needed. But according to the question, two geometries are read, aggregated by the read and afterwards de-aggregated to be used separately. If used separately, why join in the first place?
david_r
Ah, I see. I must admit I didn't take the "aggregate" bit literally in this context.
