Reading geodatbase error on attribute width
  • Jun 28, 2018 9:13 AM UTC
  • 7 replies
  • 69 views
boubcher
Forum|alt.badge.img+11
Hello There
we are reading Geodatabase and writing to PostGIS DB , the DGB reader is showing attribute width with 0 value and when we open it in ArcMap, the same attribute do have 50 value as a width, no idea why FME is not reading the value?
arc Map view
FME geoDB reader
  • Jun 28, 2018 9:22 AM UTC
Which version of FME and ArcGIS are you running?
For what it's worth, I've never seen this issue before.
  • Jun 28, 2018 10:56 AM UTC
Do the two screenshots (ArcMap and FME) show the schema of an identical table? Not only data types, but also most attribute names are different. I don't think those illustrate the same table definition.
Repost your screenshots.
boubcher
  • Jun 28, 2018 11:54 AM UTC
@david_r
we are running FME 18 and Arc MAP 10.1
boubcher
  • Jun 28, 2018 12:00 PM UTC
@takashi
Sorry I have done a new print screen for the same data
boubcher
  • Jun 28, 2018 3:38 PM UTC
we did find a way to get the with, by reading from source gdb and write to dgb
then we take the new gdb and use it as a reader, now all the with the attribute are fixed
but during the translation when writing to PostGIS we get this error
( Error executing SQL command ('CREATE INDEX "Cadastral_Dataset_Buildings_geom_153019375278" ON "Tansiq"."Cadastral_Dataset_Buildings" USING GIST ("geom")'): 'ERROR: relation "Tansiq.Cadastral_Dataset_Buildings" does not exist
boubcher
  • Jun 28, 2018 3:45 PM UTC
Just for the info we are using a dynamic transformation
this is the reader configuration
  • Jun 28, 2018 4:26 PM UTC
In your place my first option would be to re-create the reader in a blanc workspace. If that doesn't work, you may have to consider contacting Safe support.
