reading dynamic AutoCAD blocks properly
  • Mar 7, 2024 10:53 AM UTC
  • 674 views
yagami9
Hi everyone ,
I have dynamic doors in my dwg AutoCAD file :
If I click on the small arrow the door changes direction , and the big arrow changes the size of the door
I want to read on fme the default position and size of the door , just like a normal static door.
But here is how the DWG Reader reads it :
 Any Insight is much appreciated !
-Yagami
jovitaatsafe
Forum|alt.badge.img+11
Hi @yagami9,
Would you be able to try enabling on the AutoCAD reader Feature Type(s), under the Format Attributes tab, autocad_entity_visibility? If you want FME to appear as it does in AutoCAD, please try adding a Tester to the reader after enabling the reader attribute and test for autocad_entity_visibility = visible.
Does that get you the door instance output that you were expecting?
If this filtering doesn’t output the way you expected, would it be possible to share a small sample dataset (such as just an instance of the door dynamic block in the orientation you want it in as a DWG file) and I can take a closer look.
yagami9
  • Apr 3, 2024 11:00 AM UTC
Hello @jovitaatsafe !
Thanks for your reply ,
I tried the filtering you suggested , but it doesn’t work and the result still the same .
here is a sample dwg file of my dynamic doors
