reading dutch json
  • April 4, 2018
  • 5 replies
  • 34 views
robert_punt
Hi everybody, ik am trying to read an url that gives me json-format answer.
the url is like:
https://geodata.nationaalgeoregister.nl/locatieserver/v3/suggest?wt=json&q;=Nieuwe Steen 1 Hoorn
i want to read the values of the attributes "type" "weergavenaam" "id" "score"
regard,
Bert punt
Best answer by takashi
Hi @robert_punt, I think this would be a typical use case of the JSONFragmenter. After getting the JSON document with an HTTPCaller, try a JSONFragmenter with this setting.
JSON Query:
json["response"]["docs"][*]
david_r
  • April 4, 2018
Here's one way to do it:
takashi
  • April 4, 2018
JSON Query:
robert_punt
  • April 4, 2018
JSON Query:
That does the trick. @takashi
  thank you very much.
robert_punt
  • April 4, 2018
@david_r
tnak you voor your comment but the solution from Takashi uses less transformers. so i am using that solution.
david_r
  • April 4, 2018
@david_r
No worries, I agree that his solution was a bit more compact. That's the beauty of FME, lot's of ways to accomplish the same thing.
