Read SDE Terrain dataset in FME Desktop 2018.1
  • October 10, 2019
  • 30 views
sunsilk11
Hi has anyone been able to read an SDE Terrain dataset.
I would like to read this so I can obtain the z values, for specified x,y coordinates.
Best answer by markatsafe
@sunsilk11 I don't believe FME can read a Esri Terrain dataset. However the Esri documentation seems to suggest that it's more efficient to work with a raster DEM, instead of the original terrain TIN. So perhaps try converting your Terrain dataset to a Raster using the Terrain to Raster tool. FME should be able to read that.
  • October 15, 2019
sunsilk11
  • October 16, 2019
Thanks. I did just that and it works.
