Read SDE Terrain dataset in FME Desktop 2018.1
  • Oct 10, 2019 11:06 AM UTC
  • 72 views
sunsilk11
Hi has anyone been able to read an SDE Terrain dataset.
I would like to read this so I can obtain the z values, for specified x,y coordinates.
Best answer by markatsafe
@sunsilk11 I don't believe FME can read a Esri Terrain dataset. However the Esri documentation seems to suggest that it's more efficient to work with a raster DEM, instead of the original terrain TIN. So perhaps try converting your Terrain dataset to a Raster using the Terrain to Raster tool. FME should be able to read that.
  • Oct 15, 2019 4:56 PM UTC
sunsilk11
  • Oct 16, 2019 6:14 AM UTC
Thanks. I did just that and it works.
