Read or filter values based on attribute from another source
  • May 2, 2018 6:35 AM UTC
  • 5 replies
  • 329 views
I'm reading a bunch of data from a log database, transforming it and storing it somewhere else. I leave the unique ID attribute of the log message alone.
So I want to make it so my workbench only reads the logging rows I haven't processed yet. The ID numbers are ascending so my idea was to check the destination database using SQL to get the highest ID stored in there, and only read/filter from the source based on that.
Now: How do I do this? I can get the current highest ID processing using the SQLCreator, but how do i read/filter based on that?
Thanks!
Forum|alt.badge.img+63
You can use a Tester or TestFilter to select the log messages whose ID is higher than the one you got out of the database.
  • May 2, 2018 8:27 AM UTC
But when input the SQLCreator and the log database into a tester, there is on row the the max value to test against and a lot of logging rows the ID values. Comparing them doesn't work.
  • May 2, 2018 8:29 AM UTC
If you do a featurejoin you can add the id from the database to all records
  • May 5, 2018 1:23 PM UTC
If the two database tables belong to the same database, I think you can extract only required records from the source table with a single SQL statement something like this.
select * from source where (select max(id) from destination) < id
Alternatively, you can also set this expression to the WHERE Clause parameter in the reader which reads the source table.
