Read Multiple GDB saved within subfolders
galigis
Forum|alt.badge.img+20
Hi All,
What the best way of reading multiple ArcPro GDBs saved within multiple subfolders? I have looked into the Creator + FeatureReader transformers but can’t get it to work, folder structure as follows:
I would like to read the multiple GDBs form the DATA level and force FME to go through the subfolders.
Best answer by nielsgerrits
What I do is:
  • Creator
  • FeatureReader
    • Format = Directory and File Pathnames
    • Path Filter = *.gdb
    • Recurse Into Subfolders = Yes
  • FeatureReader
    • Format = Esri Geodatabase (File Geodb)
    • Dataset = path_windows
  • March 4, 2024
What I do is:
  • Creator
  • FeatureReader
  • FeatureReader
galigis
  • March 4, 2024
Thanks @nielsgerrits - it did the trick,
I’m posting the workflow below for completeness:
