Read FTP file into attribute and create list
  • Jun 24, 2019 9:38 AM UTC
  • 149 views
dbryantgeo
Forum|alt.badge.img+7
I have a predicament where I need to read a .txt file containing a list of reference numbers (example attached) .
The file is dropped by a supplier onto our SFTP.
The file usually contains customer information and therefore I don't want to store that file in a different format (e.g. csv) and read from it.
I figured that I could just use the ListBuilder to create a List from the Attribute that the file contents is stored in. However, this does not appear to work - I'm still getting a single attribute value containing the contents in the inspector.
Can anybody think of anything or am I just going to have to temporarily store, re-read and then delete the file?
Forum|alt.badge.img+54
  • Jun 24, 2019 9:48 AM UTC
If you're reading the entire text file into a single attribute you want to use an attributesplitter to split on the linebreak to create your list
palhermans
Forum|alt.badge.img+11
  • Jun 24, 2019 10:02 AM UTC
Hi. You are fine to read the txt file with the CSV reader and reference the location at the FTP. Authentification must of course be included in the reader
  • Source CSV: ftp://________/yourtextfile.txt
  • field names Line: 1
  • data start line: 2
