Read Features from .zip or .tar.gz
  • Jul 22, 2017 11:27 PM UTC
  • 5 replies
  • 193 views
My customers upload .zip or .tar.gz files to our server, I have a CSV reader, when I set the url (https://mydomain.com/customer1.zip) of a zip file with only 1 file, FME server works fine.
Now, a customer send us .tar.gz files with several files in it, for this spacific workspace I need to grab only one file form the package, there is a way to specify which will be the file in the url to process? I tried with https://mydomain.com/customer2.tar.gz\\students.txt with no luck, I manually convert to a zip file https://mydomain.com/customer2.zip\\students.txt but nothing works.
Thanks
VictorV
Best answer by pallegama
Hi @velasquezvictor,
I agree with @stalknecht of using HTTPCaller in this case. Since you are looking for using same parameter for local and remote files, you can use a workflow as depicted in the attached workspace template.
zipfile-reader.fmwt
In this workflow, source file path (local or remote) should be passed through 'Source' Published Parameter and the first Tester identifies and divert remote paths to download the zip/gz file before passing it to FeatureReader. This workspace works on both FME Desktop and FME Server.
Alternatively, you can think of writing a Startup Python script to do this.
Regards, Priyantha Pallegama
stalknecht
Forum|alt.badge.img+22
  • Jul 23, 2017 10:01 AM UTC
Hi Victor you should use a slash instead of a ". "
https://mydomain.com/customer2.tar/gzstudents.txt
HiĀ VictorĀ youĀ shouldĀ useĀ aĀ slashĀ insteadĀ ofĀ aĀ ".Ā "
HiĀ IĀ useĀ https://mydomain.com/customer2.tar.gz/students.txtĀ forĀ gzipĀ andĀ https://mydomain.com/customer2.zip/students.txtĀ forĀ theĀ zipĀ fileĀ aĀ noneĀ ofĀ themĀ works.Ā IĀ receiveĀ theĀ error:Ā
Ā
Ā
CSVĀ reader:Ā FailedĀ toĀ openĀ fileĀ 'https://mydomain.com/customer2.tar.gz/students.txt'Ā forĀ reading.Ā PleaseĀ ensureĀ thatĀ theĀ fileĀ existsĀ andĀ youĀ haveĀ sufficientĀ privilegesĀ toĀ readĀ it
Ā
IĀ verifiedĀ andĀ theĀ zip/tar.gzĀ fileĀ hasĀ students.txtĀ inside.
Ā
Ā
stalknecht
  • Jul 27, 2017 1:01 AM UTC
Ā
Ā
Ā
Ā
Ā
DoĀ youĀ runĀ itĀ fromĀ FMEĀ Server?
Ā
Ā
YouĀ canĀ useĀ theĀ HTTPCallerĀ toĀ downloadĀ theĀ fileĀ locallyĀ andĀ thenĀ useĀ aĀ FeatureReaderĀ toĀ readĀ it.
Ā
Ā
Do you run it from FME Server?
Ā
Ā
You can use the HTTPCaller to download the file locally and then use a FeatureReader to read it.
Ā
Ā
Ā
Ā
Ā
I Would Like to use the same parameter for the reader to load locally, temporary upload or a remote file.
pallegama
Forum|alt.badge.img+8
  • Jul 27, 2017 5:31 AM UTC
zipfile-reader.fmwt
