Read ALL layer names from DWG files
  • January 17, 2023
  • 470 views
Is it possible to read all layer names from a DWG source file? By all I also mean the layers which do not have any features on them.
For example, if I have a DWG file with the following layers and numbers of features on them:
  • L_01 (with 10 features)
  • L_02 (without any feature)
  • L_03 (with 1 feature)
  • L_04 (without any feature)
I want to somehow get access to all the layer names, i.e. L_01, L_02, L_03, and L_04 in FME, even though L_02 and L_04 do not have any features.
Alternatively, is there a way to convert a DWG file to a DXF file such that all layers are preserved (i.e. , again, also those that do not have any features on them)?
Best answer by lbd-kufers
Nevermind, I just found it myself:
When using the AutoCAD FeatureReader, at 'Schema/Data Features', you can specify whether only Data Features, only Schema Features, or both are to be read. In my case, I only need the 'Schema Features'.read_layers(I did not see this option when using the AutoCAD Reader, or I overlooked it.)
  • January 17, 2023
danilo_fme
Forum|alt.badge.img+57
Nice resolution.
