I want to run some Rscript and so installed an R-interpreter and installed some Libraries. As a test case I downloaded the workspace from a rather old article "RCaller: Ins and outs of using R in FME". The workspace is from 2020 though so i ran it on both 2019 and 2021 versions but it returned the same error in both cases. Actually the exact same error as mentioned in the article itself: "Failed with exit code 1 when executing R script. Output was: Loading required package: gsubfn.......". Now the article mentions to check spelling but as the workspace is an exact copy from safe I expect that to be tested and ok and furthermore that is just not the issue as the line "fmeOutput<-data.frame(meanEst,meanAct, r2, m, k)" in the Rcaller works just fine if I just pick one of the columns for output, irrespective which one. e.g. "fmeOutput<-data.frame(r2)" But the moment I comma separate a few data frame columns for output I get the error.
Any help with this appreciated.
All the best, Robbert
PS. also ran the code in RStudio where the code as-in the RCaller transformer works fine
@rokop​ I ran the workspace template rcallerlinearregression.fmwt using FME 2019.2 and it seems to work OK.
imagePerhaps check that FME is pointing to the expected R Interpreter .
imageThe example doesn't require any special packages to be loaded. rcallerlinearregressionwithgroups.fmwt also seems to work fine in FME 2019.2
I must have set the interpreter right as it is all working fine outputting 1 attribute to fmeOutput. Also tried both the 32 and 64 bit versions of Rscript. The error i get:
image" data-fileid="0694Q00000HaWCcQAN
If take off the encircled attribute meanEst it works and the line where it goes wrong then reads instead:
RCaller (InlineQueryFactory): Processing R script
RCaller (InlineQueryFactory): Generating output 'Output' using query 'SELECT * FROM "Output"'
So it seems to fail on the sql when more than 1 attribute is needed.
Cheers,
Robbert
Cheers,
Robbert
@rokop​ What OS are you running? Also what version of R do you have installed?
Try using Log Debug under Tools - FME Options - Translation tab - Log Message Filter and attach that log to this conversation.
It is odd that changing the order and number of attributes causes the crash. I don't see that here.
Hi Mark,
I'm on Windows 10 Enterprise. Running R-4.2.0 on fme 2019.2.
Please find attached the run log
Cheers,
Robbert
Hi Mark,
Cheers,
Robbert
@rokop​ Just checking - can you confirm you have installed the sqldf package ?
Perhaps also check that you do not have two versions of R installed
Hi, I have the same problem. The transformer only works when the output data frame fmeOutput only contains a single value. Otherwise it fails with the error
Error in if (fmeOutput != "") dbWriteTable(dbcon, "Output", fmeOutput, :
 the condition has length > 1
This screenshot shows it with the only line of code in the RCaller set to:
fmeOutput<-data.frame(numbers=c(1,2,3))
I wonder if an update to one of the packages used by sqldf has caused this to fail. I have the latest version of sqldf installed from Cran today along with dependencies RSQLite, proto, etc.
fme_rcaller
fme_rcaller
Hi @jo-gay Unfortunately the RCaller doesn't work with R 4.2 - FYI the issue is FMEENGINE-73477
@jo-gay​ @rokop​ we think we might have addressed this issue in FME 2022.2 - this will be available as a beta download build 22705 or higher. If someone would like to test it when the beta becomes available.
