Rcaller - Lags on "processing R script"
  • Oct 26, 2021 11:26 AM UTC
  • 67 views
I'm new to FME and tried to use the Rcaller transformer. However, the software lags at the log point "processing Rscript" and does not finish the translation but does not give back an error. This is also the case if I try to run the Rcaller example dataframe() script without any input data. See screenshots for details. Any help much appreciated.
I'm using FME 2019.2 with R >=3.6.
Translation log:
translation_logRcaller parameters:
Rcaller_parametersFME Translation Options:
FME_options
Best answer by toebr
Found a solution myself. Written down here: toebR/FME: Repo to store FME-R integration stuff (github.com)
  • Oct 28, 2021 2:34 PM UTC
