RasterToPolygonCoercer assign color to output polygons
  • Oct 12, 2018 7:29 PM UTC
  • 8 replies
  • 215 views
I have a geotiff image feeding a rasterToPolygonCoercer. I need to assign the value of the output polygons based on the input raster palette and value. How do I feed the MapInfo TAB writer the correct color from the RasterToPolygoneCoercer?
Best answer by takashi
H @jayrussell, if the raster has a palette to define colors, at first you will have to resolve the palette to transform the raster from the single band (palette entry) to 3 bands (color elements: R, G, B). You can use the RasterPaletteResolover here.
The RasterToPolygonCoercer adds an attribute called "_label" to the output polygons, which stores comma separated cell values. In the case where the raster interpretation was RGB24 (3 bands = Red8, Green8, Blue8), each cell value is in the range 0-255.
FME requires comma separated color values normalized in the range 0-1 for setting a color to features, so you also will have to add a process to normalize the color value.
This is an example, assuming that the palette defines RGB24 color.
Hope this helps.
  • Oct 12, 2018 10:54 PM UTC
Hope this helps.
  • Oct 15, 2018 12:22 PM UTC
Hope this helps.
Thank you this does help @takashi
Is there a way to retain the original palette index that was present before the RasterPaletteResolver? It represents a radar reflectivity dB that I need to retain along with assigning a color.
  • Oct 15, 2018 12:32 PM UTC
Hope this helps.
Do you mean that both the palette index and the color value (R, G, B) should be extracted? Or, need to extract only the palette index?
  • Oct 15, 2018 12:35 PM UTC
I only need to extract the palette index as an attribute. I would use the color value (R,G,B) to assign the color to the extracted polygon using your example.
  • Oct 15, 2018 12:40 PM UTC
OK. In that case, you can just use the RasterToPolygonCoercer. The "_label" attribute will store the palette index.
  • Oct 15, 2018 12:56 PM UTC
If I wanted to extract both the palette index and color value how would I retain the palette index through the RasterPaleteResolver in your original example.
  • Oct 15, 2018 1:14 PM UTC
You can use the RasterBandCombiner to make 4-band raster (palette index, red, green, blue) and then extract comma-separated those values as "_label" attribute in the subsequent RasterToPolygonCoercer.
The order of bands (palette index -> color, or color -> palette index) can be controlled by setting the Connection Runtime Order at the output port (right-click > Set Connection Runtime order) where the data flow branches into two streams. e.g. at the Junction in the screenshot below.
