RasterPyramider issues - multiple rasters created
  • Nov 22, 2017 4:07 PM UTC
  • 6 replies
  • 178 views
When I try to use RasterPyramider for freshly created GeoTIFF or JPG rasters - it creates separate raster files (the number of these equals the number of pyramid layers) - instead of pyramids of individual raster file. Is there anything in Parameters I am missing?
daveatsafe
Forum|alt.badge.img+24
  • Nov 22, 2017 8:15 PM UTC
Hi @olokedzior,
The RasterPyramider is designed to create separate rasters for each pyramid level.
The GeoTIFF writer has a setting to automatically create the internal pyramid layers for you. Add the writer to the workspace, the open the Properties of the GeoTIFF Feature Type, choose the Parameters tab, and enable Generate Pyramids:
  • Nov 23, 2017 9:03 AM UTC
Thanks Dave for a prompt reply,
however I don't seem to have that option:
  • Nov 24, 2017 5:25 PM UTC
Hi @olokedzior,
Thanks Dave, I can't see the options you showed...
fmelizard
Forum|alt.badge.img+22
  • Nov 27, 2017 4:43 PM UTC
Hi @olokedzior. What version of FME are you using? (Help > About FME Workbench).
The parameter is available in FME 2017+
  • Nov 28, 2017 8:24 AM UTC
Hi Natalie, it's 2016.1.2.1
daveatsafe
  • Dec 2, 2017 12:04 AM UTC
Hi @olokedzior,
What writer are you using, and in which version of FME?
