Rastermosaicker adds data (0,0,0)
salvaleonrp
Forum|alt.badge.img+23
My workspace created this QR code with a description below it was created by a rastermoasaicker from two png files - one for the QR and another one for the text below it.
The blue section with text extends by about 300 pixels more than the QR code - string length is up to 50 characters. When the raster mosaicker merges the two pictures together the nodata section of the merge is now replaced with black pixels. On RasterMosaicker, I tried "Overlapping Values: Last with Nodata Overwriting Data to No" and Overlapping Values: Maximum (255) and netheir one worked.
I prefer to have it white or no data. So far every thing I've tried has not worked yet. Any suggestions?
daveatsafe
Forum|alt.badge.img+24
Hi @salvaleonrp,
In the ImageRasterizer that creates the text image, set Interpretation Type to RGBA32.
Use a RasterInterpretationCoercer to coerce QR image to RGBA32 before mosaicking.
In RasterMosaicker, set Overlapping Values to 'Composite Using Alpha Band'.
This will make all the extra pixels transparent.
geospatiallover
Participant
@DaveAtSafe, after trying what you suggested, the pixels became transparent but the rasters did not merge. I'm back to where I was yesterday.
When rasters were merging, the QR code starts off as UINT8 with Band 0 and palette 0 (RGB24). The second PNG is 3 bands - Red8, Green8, Blue8) all with the value of 255 on the color black. I used the PaletteResolver on the QR code and the QR Code changed to 3 bands (Red8, Green8, Blue8) with Value 0 on black. This translation produced the merged but with the black square next to the QR code.
It's almost there. What else can I try?
