Raster tiles lose spatial reference
  • Feb 11, 2015 2:48 PM UTC
  • 9 replies
  • 80 views
Hi All,
I am currently trying to load in some raster tiles that I have downloaded from the European Space Agency in FME. I have already successfully displayed them in ArcMap and are in a D_WGS_1984 projection. FME does not seem to recognize the spatial reference as it cannot display them in the visualizer and when any transformers are used, they seem to turn them upside down and out them at the origin of any projection that they are set to.
Has anyone else found this problem before who could maybe help out or is this just a problem that is unique to the dataset I am using?
Many Thanks
  • Feb 11, 2015 4:34 PM UTC
Are you sure you use the correct reader? Also be careful about specifying the coordinate system on the reader unless you're 100% sure that you specify the right thing, as it will override whatever coordinate system info is contained in the raster.
David
David has very valid points and I would definitely QC that first. I would then carefully (as he pointed out) specify the coordinate system on the Reader as LL84. That is FME's default WGS84 coordinate system and your raster, for whatever reason, my not be read in correctly in that regard.
See here for more details on how FME handles LL84: http://fmepedia.safe.com/articles/FAQ/Spherical-or-Web-Mercator-Coordinate-System
Hi Guys,
I've tried specifying the projection on the reader as you said but no success unfortunately. Any other suggestions?
Doug
  • Feb 12, 2015 11:19 AM UTC
did you also try to leave the coordinate system blank (not set)? That will force FME to try and imply the coordinate system from the dataset.
David
Hi David,
Yes, thats what I tried first of all and that hasn't worked either. I've also tried reprojecting with no luck.
Thanks,
Doug
Can you provide a link to a sample of the data?
https://scihub.esa.int/dhus/
All data is downloaded from here.
fme_noob
  • Apr 4, 2019 4:40 PM UTC
Did you figure this out? I'm having a similar issue.
xiaomengatsafe
Forum|alt.badge.img+11
Hi @fme_noob, Thanks for your question. I think to help debug your specific problem, our experts in the community will likely need to know a bit more about the details. Since this thread is quite old, I'd recommend that you post a new question, and include a more detailed description of your issue, and maybe include a sample of your data and the workspace you used.
