Raster rotation
  • Dec 9, 2025 6:09 PM UTC
  • 122 views
mszwaya
Participant
Forum|alt.badge.img+5
I have a raster broken up into a grid of raster cells using RasterTiler.  I want to rotate each cell X degrees (not the whole raster) in place.  I do *not* want to rotate around the upper left corner.  I need the cell to rotate and remain in the exact location.
As I understand it, my process is using the following transformers:
  1. RasterCellOriginSetter: Set to 0.5,0.5 (the center)
  2. Rotator: Set Rotation Angle to X.
  3. RasterRotationApplier: Interpolation Type = Bilinear.
When I do this, the cells are rotated around the upper-left corner rather than the centroid.
Do I have the correct transformers & settings for this application?
dmitribagh
Forum|alt.badge.img+20
  • Dec 12, 2025 7:25 PM UTC
Hi ​@mszwaya,
Do I understand correctly that you actually want to rotate tiles, not cells (pixels)? RasterCellOriginSetter applies to cells, not rasters as a whole. It is a rarely needed transformer. In order to rotate each tile around its centre, you need to extract the coordinates of the centre (CenterPointExtractor) and supply the extracted coordinates to the X and Y Origin parameters in Rotator. Then each tile rotates around its centre.
Raster Tile Rotation
You can also achieve this with Affiner, which gives a lot more power (with a lot more math).
You may also want to use RasterBandAdder or RasterBandNodataSetter before rotation so that the pixels added after RasterRotationApplier are transparent. See the attached workspace.
If I misunderstood your question, please let me know, I’d be happy to dive deeper.
Dmitri
