Raster Band Value Average
  • Nov 6, 2017 11:25 AM UTC
  • 5 replies
  • 128 views
I have what I think is a fairly simple question. I just want to calculate the average of all the cells in one band on a raster. I am using FME2017.0.
Is there a simple way to do this without having to convert the rasters to vectors (points) and then using StatisticsCalculator
Thanks
Forum|alt.badge.img+63
I'm not sure whether it's actually producing a proper average value but...
If you resample (RasterResampler) it to 1x1 pixel you'll get something that, at least in the trials I've done, appears to be pretty correct. It's also very fast (which I think running statistics on a lot of pixels is not)
  • Nov 6, 2017 12:26 PM UTC
Another thought. You can use the PointCloudCombiner to transform it into a point cloud, and then calculate Mean of required component values with the PointCloudStatisticsCalculator.
  • Nov 6, 2017 4:30 PM UTC
Great thanks guys, I will try those methods out :)
  • Nov 6, 2017 4:38 PM UTC
Thanks @takashi this method worked perfectly.
  • Nov 6, 2017 4:43 PM UTC
Thanks @redgeographics
This method worked for some of my rasters (but the mean was a centimeter or so different to what was calculated using other methods), but not for all my rasters (some of them resulted in a single cell of No Data).
