Raster Aggregation
I have an ASCII grid with a cell size of 1km2, I was wondering if there was a way to aggregate these cells into 5km2 grid squares. I initially thought of using RasterResampler, but there is no option to sum the attributes.
For those familiar with ArcGIS i esentially want the equivilent of the tool 'Aggregate'
Thanks,
Ed
gio
Forum|alt.badge.img+15
  • April 17, 2014
Hi,  I think u need to usea rastermosaicker first and then use a rasterresampler
Gio
  • April 17, 2014
Thanks Gio,
I'm sure that solves my problem however, as the interpolation type i require is a sum of the atributes, whereas the rastermosaicker and rasterresampler only have averaging, nearest neighbor etc.
Thanks,
Ed
gio
  • April 17, 2014
Then i assume u have overlapping gridcells.
you can use rasterexpressionevaluator for such.
There are good examples in the knowledge base here. Just search on the topic of rasters in there.
Gio
fmelizard
Forum|alt.badge.img+22
HI,
Typical case for some math on the cell values, I would think.
Essentially calculating the desired value and applaying the difference to each cell can  preserve the raster properties and  change the cell values to the desired value.
