Quiz! Difficulty: Hard. Make a recursive Clipper
  • Apr 19, 2021 8:56 AM UTC
  • 94 views
sigtill
Forum|alt.badge.img+25
I want to clip 2000 partially overlapping areas with each other. And they are sorted and given a priority in the order they need to be clipped. Attached is an example workspace that uses text as a sample. Shown below are the result. The letter "F" is the first clipper, then "M", then "E" etc. Så every area/letter is behind the other one.
The attached workspace shows the approach.
How can I wrap the equal processes within the "New Bookmark" into a custom transformer that works recursively so I dont need to copy/paste these bookmarks x number of times.
Good luck!
Best answer by geomancer
Aren't you overcomplicating things?
I used an AreaOnAreaOverlayer writing the _count attribute to a list, a ListSorter to ensure list element 0 contains the lowest _count value, a ListIndexer to write the value of element 0 back to _count, and a Dissolver to merge the polygons on attribute _count.
Dissolved
geomancer
Forum|alt.badge.img+71
  • Apr 19, 2021 10:03 AM UTC
Dissolved
sigtill
  • Apr 19, 2021 10:26 AM UTC
Dissolved
This is exactly why I love this forum. Great answer to my solution and using completely different Transformers than I thought was needed. Thanks for a great solution @geomancer​ !
