Quick Test of Hub Transformer
  • Dec 1, 2017 10:01 PM UTC
  • 122 views
mark2atsafe
Forum|alt.badge.img+59
Hey folks,
If anyone has a couple of minutes to spare, could you do me a favour and test this transformer on the FME hub: https://hub.safe.com/transformers/spatialsorter
It should run to completion (and not fail in a Python error) and it should return output like this: https://www.screencast.com/t/kRP9ysTq3N (I ran it on the Parks training dataset, but it should work on any dataset).
Thanks. I've had problems where it works on one machine but not another. I thought I had it cracked, but the test workspace fails on the hub. I'd like to check if it's just the hub (or just linux) or if everyone has issues.
Mark
  • Dec 2, 2017 3:16 PM UTC
Hi @Mark2AtSafe, with Python 3.x interpreter, it seems that the numeric values contained by a numpy.ndarray have to be cast to "int" or "float" values explicitly when you pass them to the FMEFeature.setAttribute method. Try this.
def processFeature(feature):
    curvenum = feature.getAttribute('SortPrecision')
    for i, s in enumerate(hilbert_curve(curvenum)):
        for j, v in enumerate(s):
            feature.setAttribute('_list2{%d}.sub{%d}' % (i, j), int(v))
In addition, the "numpy.ndenumerate" function could be used effectively here.
    for (i, j), v in ndenumerate(hilbert_curve(curvenum)):
Hope this helps.
  • Dec 3, 2017 12:19 AM UTC
Hope this helps.
For what it's worth, this implementation could increase the performance a bit.
spatialsorter-update-test-2.fmw
mark2atsafe
  • Dec 4, 2017 6:28 PM UTC
Hope this helps.
Thank you Takashi! I implemented the int(v) part and it works fine now. I'm not going to try the other parts because now it is working I don't want to touch anything else!
