Query partitioned CosmosDB collections
  • Dec 14, 2017 11:56 PM UTC
  • 6 replies
  • 82 views
poly_jan
Hello everyone,
I'm using FME Desktop 2017.1 to read from a CosmosDB colleciton. This works fine for single-partition collections, but with partitioned collections FME raises an error telling me that the "x-ms-documentdb-query-enablecrosspartition" needs to be set. Has anyone experienced this and found a workaround, or am I missing a setting somewhere?
The alternative would be to use the CosmosDB REST API, but that would be quite a bit of effort so isn't really an option at the moment.
Thanks,
Jan
Best answer by richardatsafe
Hi @g3,
Unfortunately, partitioned collections are not supported yet with FME, but I can add you to the request.
richardatsafe
Forum|alt.badge.img+11
  • Dec 15, 2017 12:17 AM UTC
Hi @g3,
poly_jan
  • Dec 19, 2017 12:33 AM UTC
Hi @g3,
Hi Richard, thanks for the quick reply, that'd be great thanks.
Hi @g3,
Hi, just wondered if this is supported yet?
xiaomengatsafe
Hi @baznewman07, This is not yet supported, as we've not had many request for this yet. We will post an update on this Q&A; thread if/when the feature is implemented. If this function is very important to you, you can increase the priority of it by posting it as a New Idea, where others can add their vote for the idea as well.
Ok thanks for that, i have added this idea:
https://knowledge.safe.com/idea/77933/add-the-ability-to-query-partitioned-cosmosdb-coll.html
xiaomengatsafe
Thank you @baznewman07
