QR Code Generator - batch production
  • Oct 13, 2021 2:18 AM UTC
  • 8 replies
  • 306 views
I'd like to create a WB that is capable of QR code batch production to a PDF suitable for printing. The input would be a spreadsheet containing the QR codes (text) in a column. I have the QR Code Generator but not sure how to enable it to write multiple codes. Does anyone have experience with this or recommend a B build?
jhawks
Forum|alt.badge.img+7
  • Dec 5, 2022 4:17 PM UTC
Bumping, need the same thing. Were you able to resolve this?
Forum|alt.badge.img+54
  • Dec 5, 2022 4:35 PM UTC
The QR Code Generator will produce a QR code for each input sent to it, so you just need to send multiple features in and set the data parameter to the relevant attribute to get multiple qr rasters out
jhawks
  • Dec 5, 2022 4:42 PM UTC
Fantastic! although first I have to get it run once on just one, struggling.
jhawks
  • Dec 5, 2022 5:23 PM UTC
Uneducated question, this is the transformer, but there's no QR code writer?
  • Dec 5, 2022 5:38 PM UTC
The output is a raster image so you can just need to choose a raster format to write to, e.g. png, jpg etc.
jhawks
  • Dec 5, 2022 5:56 PM UTC
Got it, jpg fought me some, png worked! Thanks.
Hi @jhawks​  appreciate the bump. We got our QR codes printed at a sign writer and they have software to generate the codes on our behalf. So in the end I didn't need FME for the batch generation. For some reason I couldn't get the transformer to generate more than one QR code so not sure what I was doing wrong. I will take another look today.
jhawks
  • Dec 9, 2022 2:24 PM UTC
Were you able to get it to do batch conversion? Since the text input is done in the transformer, it seems impossible, unless I'm missing something (likely).
