PythonCaller: Use logMessageString Problems with Encoding
  • September 18, 2013
  • 7 replies
  • 27 views
Hello!
I'm using the PythonCaller to write lines into the log message.
I use logMessage String and with data that has mutated vowels I get following error message:
Python Exception <UnicodeEncodeError>: 'ascii' codec can't encode character u'\\xfc' in position 67: ordinal not in range(128)
What can I do that I can write also data with ä,ü,ö to the log message?
Thanks for your help!
Isabell
Hi Isabell,
  I also often encounter such a situation. My environment is Japanese locale.
My workaround is to test whether the character string is a unicode instance or not, and to encode the string by the default encoding if it's unicode.
# Example
import fmeobjects
import locale
class FeatureProcessor(object):
    def __init__(self):
        loc = locale.getdefaultlocale()
        self.enc = loc[1# save the defualt encoding
        self.logger = fmeobjects.FMELogFile()
    def input(self, feature):
        s = feature.getAttribute('attr')
        if isinstance(s, unicode):
            self.logger.logMessageString(s.encode(self.enc))
        else:
            self.logger.logMessageString(str(s))
    def close(self):
        pass
I'm not sure whether this workaround works fine in your locale.
Hope more suitable solution will be provided.
Reference link: Unicode HOWTO http://docs.python.org/2/howto/unicode.html
Takashi
it's a bit tricky, because text attributes in FME are usual encoded as Unicode, where as the logMessageString() function seems to expect Latin1 encoding, for some unknown reason.
But try this:
log_text = feature.getAttribute("my_text").encode("latin1")
FMELogFile().logMessageString(log_text, fmeobjects.FME_WARN)
The important part is in bold. Please let us know if this works for you.
David
@Takashi: for what it's worth, your suggestion works find with my Swiss locale settings.
I like your more general approach. Thanks for sharing!
David
Hello!
I tried Takashi's suggestion and it works fine!!!
Thank you both very much for your help!
Regards
Isabell
Forum|alt.badge.img+5
  • February 10, 2016
Start your python script with the coding and for each variable you can add (@var).encode('utf-8')
# -*- coding: utf-8 -*-
  • August 25, 2016
Hi there, @isabell, @david_r, @julien,
I found this description in the FME 2016.1.1.0 "What's New" list.
FME 2016.1.1.0 16593 20160620
Python: Modified logMessage() and getMessage() to allow mixed unicode and str values in the message parameters. Fixed encoding of source code passed from PythonFactory to Python interpreter. (PR#70683)
Confirmation. This script within a PythonCaller (FME 2016.1.1 build 16609) was executed without error :-)
import fmeobjects
    def __init__(self):
        msg = feature.getAttribute("attr")
        if isinstance(msg, unicode): # check if the value is a unicode instance
            self.logger.logMessageString("the value is a unicode instance")
        self.logger.logMessageString(msg)
  • August 25, 2016
import fmeobjects
    def __init__(self):
Hi Takashi, thanks! Yes, I saw that too, excellent news indeed.
