I'm using the PythonCaller to write lines into the log message.
I use logMessage String and with data that has mutated vowels I get following error message:
Python Exception <UnicodeEncodeError>: 'ascii' codec can't encode character u'\\xfc' in position 67: ordinal not in range(128)
What can I do that I can write also data with ä,ü,ö to the log message?
Thanks for your help!
Isabell
